  • Gurux Club
  3. HLS Password
HLS Password
By kristupas, 5 December, 2022
I would like to know which HLS authentications require password? I see HLS password, but I am not quite sure which authentications use it. Is password used as a secret? As far as I understand only GMAC and ECDSA does not require password, right? Which values you should know before connection for SHA1, MD5?
9 months 3 weeks ago
High, MD5, SHA1, and SHA256 require a password. Password is not used as a secret. Both client and server generate the challenge that is with the password used as a secret.
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
  • azcah
  • Robertciz
  • Ilushikqtg
  • Margaretyhs
  • Mariohag
