If communication is suddenly stopped while communicating using a thread, a dead lock occurs in the lock in Gurux DLMS. Is there a good way to solve this?
If you want to read concurrently multiple meters using RS-485 you need to create your own client for each thread. There is a frame sequence counter for each connection and this causes you can't share one GXDLMSClient instance for multiple threads.
During 1:1 communication, when DLMS disconnect is transmitted to stop communication with the meter, a dead lock often occurs in the lock of Guux DLMS. Is there any good way to solve this?
If you are using DLMS and RS-485 then it (daisy chaining) should be possible. You can't read multiple meters with RS-232.
I can't understand what a
I can't understand what a daisy chaining
Is it a multi-drop function?
Daisy chaining is the same thing as multi-drop in terms of RS-485.
HI,
HI,
There shouldn't be any deadlocks. Can you describe when this occurs or tell more?
