  • Gurux Club
  3. Which Source is the last version?
By AliDev7, 24 July, 2022
Gurux.Net
I'm try to create Client and server AMR from your Library (.Net). there are multiple source codes and document that I see in your website and in github repository. I wonder which on is the last version?
Because I have problem to implement sample codes. like this :
// Step 2: Initiate the Image transfer process.
ReadDataBlock(Client, Media, target.ImageTransferInitiate(Client, Identification, data.Length), reply);
'ReadDataBlock' function has two input, but in your code, you pass 4 input parameters to this function.
I appreciate if you help me with this :)
1 year 2 months ago
You can use DLMS Client example to read your meter and modify it for your needs.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E…
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
  • azcah
  • Robertciz
  • Ilushikqtg
  • Margaretyhs
  • Mariohag
