Because I don't know what programming language you are using I spoke at a general level.
Update value to the register component and then write it. Make sure that you have enough access rights. I believe that the best way to start is to write the register value with GXDLMSDirector.
The data type must be correct or the meter returns a write error.
Hi Hemant Kumar,
Hi Hemant Kumar,
