  3. Error Convert Datetime
Error convert datetime
By mbathe, 23 February, 2022
Known problems
When I read a date I get a hexadecimal string for example "07E40205030B391200000002" I would like to know how to convert this string into a date in C# and python
the solutions proposed for this same problem do not work for me
4 years 1 month ago
You can use GXDLMSClient.ChangeType to convert byte array to date-time.
Something like:
GXDateTime dt = (GXDateTime) GXDLMSClient.ChangeType(YOUR_BYTE_ARRAY_VALUE, DataType.DateTime);
There is an error on the clock status (The last byte in your hex string). The value is 2 and it's not used (reserved) in DMLS standard. Convert works, but that status state is lost.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
  • ZJT
  • Dragoslav
  • GiuseppeB
  • tepa_pa
  • zeroday-pt
