  3. Error While Start Conformance Test With Gurux.DLMS.AMI
Error while start conformance test with Gurux.DLMS.AMI
Profile picture for user riahtu
By riahtu, 18 February, 2022
Known problems
I am using DLMSDirector with Gurux.DLMS.AMI
When start a conformance test, I get the popup error message:
Unable to cast object of type 'Gurux.DLMS.GXDLMSMeter' to type 'GXDLMSDirector.GXDLMSDevice'.
What could be the bug? Thanks in advance for your help.
Best regards,
Uthai
3 years 9 months ago
Hi Uthai,
Hi Uthai,
Conformance tests are not planned to work with Gurux.DLMS.AMI. Conformance tests are for meter developers when they are using a direct connection for the meter.
riahtu
In reply to Hi Uthai, by Kurumi
Thank you.
Thank you.
Best Regards,
Uthai
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • SNRM byte mening
  • diroccon
  • amelara
  • stasxol
  • Shaheer Tariq
  • Jagi_prg
