By aeeccims@tnebnet.org, 8 October, 2021 Forums Gurux.DLMS.AMI Hi I am new to DLMS subject and in the process of development of MDAS for the organisation. We have only linux environment for server and need to set up in linux environment only. Is it possible to set up in Linux If so any guidance is appreciated. Thank you in advance Hi, Hi, 1. You need to install dotnet for the linux. 2. Then build the Gurux.DLMS.AMI dotnet buid Gurux.DLMS.AMI.sln 3. Start the Gurux.DLMS.AMI. dotnet Gurux.DLMS.AMI.dll BR, Mikko Hi Mikko Hi Mikko Thank you so much for fast response. I try and get back in case any further clarifications. Thank you once again. Log in or register to post comments
Hi Mikko
Hi Mikko
