  3. MQTT Broker and MQTT Bridge Exe and DLL Files.
MQTT Broker and MQTT bridge Exe and DLL files.
By manish ojha, 1 March, 2021
Gurux.MQTT
Dear Sir,
I am working on the getting the meter data thru MQTT , for which I downloaded the codes fo the Gurux MQTT folder, But i am unable to work as .dll and exe files are missing.
How do i can get the same, Please help.
Regards
Manish Ojha
4 years 10 months ago
Dear Manish Ojha,
Dear Manish Ojha,
You need to build the application. You can try to run "dotnet build" in that folder. It will build the application.
manish ojha
Dear Sir
Dear Sir
I build the code but it is giving the error message as per attached screen shot, where i am missing. please help
Hi Manish,
Hi Manish,
This is not an exe that you try to run. Try to run bridge and broker to get started.
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • 6-digit field values from meter not fully received (only 5 digits shown)
  • Gurux DLMS Android App
  • FRANCISCO
  • Supun Ellewela
  • Mario
  • brianmon
  • dejanm
