  • Gurux Club
  3. Limiter - Normal Threshold
Profile picture for user Remith
By Remith, 2 September, 2020
I am trying to write the Limiter Normal Threshold parameter through Gurux Java library. Getting below exception.
gurux.dlms.GXDLMSException: Access Error : Device reports a unmatched type.
Below is my code,
GXDLMSLimiter lm = new GXDLMSLimiter("0.0.17.0.0.255");
lm.setThresholdNormal(18720);
com.writeObject(lm, 4);
Other parameter I am able to write. Only facing problem with Threshold Normal.
Gurux DLMSdirecter also its working.
Kindly help me to resolve this issue.
2 years 6 months ago
I believe that your datatype is wrong. You need to read it first to update the data type or give it like this:
lm.setThresholdNormal(GXUInt32(18720));
Change GXUInt32 to the correct data type.
Remith
2 years 5 months ago
It worked .... Thank you.
Profile picture for user kevin jose minj
kevin jose minj
2 months 2 weeks ago
In reply to It worked .... Thank you. by Remith
Can you tell me which
Can you tell me which datatype you used for writing the value?
Remith
In reply to Can you tell me which by kevin jose minj
Read the object first. Gurux
Read the object first. Gurux automatically identify the data type.
After you can set the value and write back
kevin jose minj
In reply to Read the object first. Gurux by Remith
Can you show the example code
Can you show the example code?
kevin jose minj
In reply to Can you show the example code by kevin jose minj
data = GXDLMSLimiter('0.0.17
data = GXDLMSLimiter('0.0.17.0.0.255')
val = self.read(data,4)
data.value = 200
self.write(data, 2)
this is my code
Remith
In reply to data = GXDLMSLimiter('0.0.17 by kevin jose minj
Look like you are reading 4th
Look like you are reading 4th index and writing to 2nd index
Fri, 03/24/2023 - 14:22
gurux.dlms.c 20230324.1
Thu, 03/23/2023 - 11:01
GXDLMSDirector 9.0.2303.2301
Thu, 03/23/2023 - 09:10
Gurux.DLMS.Python 1.0.142
Wed, 03/22/2023 - 13:51
Gurux.DLMS.Net 9.0.2303.2201
Wed, 03/22/2023 - 10:15
gurux.dlms.c 20230322.1
Open bugs
Gurux.DLMS.AMI4
1
Gurux.DLMS.Android
1
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
