I am using DLMS java client. I want to know that is it possible to add new feature in dlms. Like currently we are communicating using serial and wiffi connection...but what if i want to communicate using url.
Actually i am facing some problem...for communication using url i want to use some dlms method directly in a new class in new package without setting any properties. But i am unable to access that because of invisibility and without setting properties i can't go ahead.
Adding new feature
I believe that best way to solve this is if you build an app where is a REST interface. In that way, you can configure your app as you like to.
