I am using DFE meter. I cannot find the Gurux DLMS Director files (*gxc). I have tried several methods but I cannot get the .gxc file for the DFE meter.
Please let me know the procedure for getting the .gxc file.
First you need to check is your meter supporting DLMS. If it is, you need to connect to the meter. GXDLMSDirector will automatically read all supported registered when connecting the first time.
DFE meter
Can you please tell me what are all the meters which support gurux?. Will all the meters which supports DLMS will be supported by gurux director?.
Thanks and Regards,
SelvaMurugan.T
Supported meters
You should be able to read all DLMS complicated meters with GXDLMSDirector.
