Decrypted log
6 posts / 0 new
Last post
sluge
sluge's picture
Decrypted log
I'm working with meter that uses Encryption and Authentication. I log my exchange with meter, it is several MBs, but all data are ciphered. Is any way in DLMS Director to log decrypted data to the log, because there are no ways to decrypt it?
Kurumi's picture
You can do this if you select "Xml" and Comments from "View Log".
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
sluge
sluge's picture
Hello Mikko,
I've set xml and comments, but unfortunately no decrypted APDS and no comments at all
Kurumi's picture
I just check this. I'm sorry, data is decrypted to trace view, not log file.
If you select "Pdu" and "Comments" from "Trace" menu you see something like this:
<!--Decrypt data:
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<Enum Value="00" />
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
<glo_GetResponse Value="3000000008A5256B89C71637D3DAA6017D07D012A34982" />
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
sluge
sluge's picture
Thanks, that's working Ok. But better to add this feature to log also
Kurumi's picture
Reason for this is that log is same for all the clients and each client might have own encryption settings. I'll add this to the work list, but this is with a low priority.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
