By sakshi, 29 May, 2018 Forums Gurux DLMS for Java Hi, I want to know where are obis code descriptions available in dlms client for java? When i run dlms client i get logical name and class name. But it gives "invalid" description for all. Description of OBIS code in dlms client for java Hi, Can you give example from the OBIS code that you are using? All OBIS codes are described on OBISCodes.txt file. BR, Mikko output-: output-: { Reading -> GXDLMSRegister , name : 1.0.91.7.0.255 , descriprtion : Invalid Reading -> GXDLMSRegister , name : 1.0.12.7.0.255 , descriprtion : Invalid } 1.0.91.7.0.255 is for Neutral Current 1.0.12.7.0.255 for voltage But it is giving "descriprtion : Invalid" Description of OBIS code in dlms client for java Hi, I just verify this: 1.0.91.7.0.255: Ch. 0 Lo Current (neutral) Inst. value 1.0.12.7.0.255: Ch. 0 Voltage: any phase Inst. value Have you made changes to the source code? What version are you using? GXDLMSConverter t = new GXDLMSConverter(); Object val1 = t.getDescription("1.0.91.7.0.255", ObjectType.REGISTER); Object val2 = t.getDescription("1.0.12.7.0.255", ObjectType.REGISTER); BR, Mikko No i dint change anything in No i dint change anything in source code. <artifactId>gurux.dlms.client.example.java</artifactId> <version>0.0.1-SNAPSHOT</version> I have also tried below code. GXDLMSConverter t = new GXDLMSConverter(); Object val1 = t.getDescription("1.0.91.7.0.255", ObjectType.REGISTER); It is giving invalid. Description of OBIS code in dlms client for java Hi,ยจ What is your gurux.dlms component version? <groupId>org.gurux</groupId> <artifactId>gurux.dlms</artifactId> <version>2.2.10</version> BR, Mikko Hi It is 2.2.9. <groupId>org.gurux</groupId> <artifactId>gurux.dlms</artifactId> <version>2.2.9</version> Hi I have changed the version to 2.2.10 in pom.xml Now it is giving correct description. Thankyou Log in or register to post comments
output-:
output-:
I just verify this:
Hi,ยจ
It is 2.2.9.
Thankyou
