I am trying to connect to a meter that uses HDLC addressing. The manufacturer has said the system uses 2-byte HDLC addressing scheme. The physical device address given is 66 and the logical device id is given as 1. What server id I should use in order to connect to the meter?
I was able to connect to the meter using Gurux Director as it takes different values for physical and logical addresses. But from code I am not able to do so. Through code in response to SNRM request I am not getting any response. It looks to me I may not be able to pass correct server id through code. Can you please check it ASAP?
Server id for HDLC addressing
Any update on this?
Yatin
Yatin
You can use GXDLMSClient.getServerAddress-method to generate server address from physical and logical device address.
