I made one demo project with 10 Energy meter.
All 10 meter are connected with Mess Network.
There is one RF+GSM gateway which is connected with Mess network too.
Meter has its own protocol ,not DLMS,and all work fine,i got date on server side.
now I have one sample Energy Meter ,which have indian Standard.
I have optical port, which is connected with computer via serial port.
I install Gurux GXDLMSDirector Ver 8.1
I attached device properties screenshot
Next step I click on connect button
got massage as under
(you need to read Association view to see all objects what the
meter can offer. Do you want to do it now ?) https://ibb.co/jv5o77
can Any one guide me what to do next to read data ,Resistor etc.
and if i want to get data on my serial port than how to read and right Resistor and data.??
which information i have to know about my meter??
I'm sorry for the slow reply. I have not seen your post.
The reason, why you are not seeing your register and data objects, is that your meter is showing only a small part of the data when connecting without authentication level and password.
You need to change the authentication level and password. Then you can see more objects.
GXDLMSDirector
