read LINYANG meter's OBIS
11 posts / 0 new
Last post
samira
I try to read LY-SM100. I used Certification No. 1858 information of dlms site
http://www.dlms.com/conformance/listofcompliantequipment/index.html
and create a new manufacture and then add device like this:
https://www.gurux.fi/sites/default/files/styles/thumbnail/public/forum/d...
I can receive this log
2:46:42 PM Initializing serial connection.
2:46:42 PM 02:46:42.736 Info Opening
2:46:42 PM 02:46:42.736 Info Serial Port Settings: Port Name: COM8 Baud Rate: 300 Data Bits: 7 Parity: Even Stop Bits: One Eop: None
2:46:42 PM 02:46:42.846 Info Open
2:46:42 PM HDLC sending:/?!<CR><LF>
2:46:42 PM 02:46:42.846 Sent 2F 3F 21 0D 0A
2:46:43 PM 02:46:43.408 Received 2F
2:46:43 PM 02:46:43.440 Received 2F
2:46:43 PM 02:46:43.486 Received 4C
2:46:43 PM 02:46:43.518 Received 59
2:46:43 PM 02:46:43.549 Received 45
2:46:43 PM 02:46:43.580 Received 33
2:46:43 PM 02:46:43.611 Received 5C
2:46:43 PM 02:46:43.643 Received 32
2:46:43 PM 02:46:43.674 Received 37
2:46:43 PM 02:46:43.705 Received 35
2:46:43 PM 02:46:43.736 Received 33
2:46:43 PM 02:46:43.768 Received 76
2:46:43 PM 02:46:43.815 Received 35
2:46:43 PM 02:46:43.846 Received 73
2:46:43 PM 02:46:43.893 Received 6D
2:46:43 PM 02:46:43.924 Received 74
2:46:43 PM 02:46:43.955 Received 0D
2:46:43 PM HDLC received: /LYE3\2753v5smt<CR><LF>
2:46:43 PM BaudRate is : 2400
2:46:43 PM Moving to mode E.
06 32 33 32 0D 0A
2:46:43 PM 02:46:43.955 Sent 06 32 33 32 0D 0A
2:46:44 PM 02:46:44.565 Received 49
2:46:45 PM 02:46:45.971 Info Closing
2:46:46 PM 02:46:46.111 Info Closed
2:46:46 PM 02:46:46.111 Info Opening
2:46:46 PM 02:46:46.111 Info Serial Port Settings: Port Name: COM8 Baud Rate: 2400 Data Bits: 8 Parity: None Stop Bits: One Eop: None
2:46:46 PM 02:46:46.205 Info Open
2:46:47 PM Send SNRM request.
7E A0 07 03 2D 93 AF A8 7E
2:46:47 PM 02:46:47.221 Sent 7E A0 07 03 2D 93 AF A8 7E
2:46:47 PM 02:46:47.971 Received 49 7E
2:46:47 PM 02:46:47.986 Received A0 20
2:46:48 PM 02:46:48.002 Received 73 D0 3D 81
2:46:48 PM 02:46:48.018 Received 80 14 05 02
2:46:48 PM 02:46:48.033 Received 02 11 06 02
2:46:48 PM 02:46:48.049 Received 02 11 07
2:46:48 PM 02:46:48.065 Received 04 00 00 00
2:46:48 PM 02:46:48.080 Received 01 08 04 00
2:46:48 PM 02:46:48.096 Received 00 00 01 FC
2:46:48 PM 02:46:48.111 Received A8
2:46:48 PM
49 7E A0 20 2D 03 73 D0 3D 81 80 14 05 02 02 11 06 02 02 11 07 04 00 00 00 01 08 04 00 00 00 01 FC A8 7E
2:46:48 PM Parsing UA reply succeeded.
2:46:48 PM Send AARQ request.
7E A0 2B 03 2D 10 5B 06 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
2:46:48 PM 02:46:48.111 Sent 7E A0 2B 03 2D 10 5B 06 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
2:46:49 PM 02:46:49.033 Received 7E A0
2:46:49 PM 02:46:49.049 Received A0 4C 2D
2:46:49 PM 02:46:49.065 Received 30 9F 43
2:46:49 PM 02:46:49.080 Received E6 E7 00 61
2:46:49 PM 02:46:49.096 Received 3E A1 09 06
2:46:49 PM 02:46:49.111 Received 07 60 85 74
2:46:49 PM 02:46:49.127 Received 05 08 01 03
2:46:49 PM 02:46:49.143 Received A2 03 02 01
2:46:49 PM 02:46:49.174 Received 01 A3 05
2:46:49 PM 02:46:49.190 Received A1 03 02 01
2:46:49 PM 02:46:49.205 Received 02 A4 0A 04
2:46:49 PM 02:46:49.221 Received 08 4C 59 45
2:46:49 PM 02:46:49.236 Received 64 72 FB 16
2:46:49 PM 02:46:49.252 Received 5F BE 19 04
2:46:49 PM 02:46:49.268 Received 17 2E 15
2:46:49 PM 02:46:49.283 Received 30 1B 51 89
2:46:49 PM 02:46:49.299 Received E7 06 25 DA
2:46:49 PM 02:46:49.315 Received CF 13 12 45
2:46:49 PM 02:46:49.330 Received B7 5F D7 E5
2:46:49 PM 02:46:49.346 Received 36 A4 2C 2B
2:46:49 PM 02:46:49.361 Received 22 37 CB
2:46:49 PM
7E A0 4C 2D 03 30 9F 43 E6 E7 00 61 3E A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 02 A4 0A 04 08 4C 59 45 64 72 FB 16 5F BE 19 04 17 2E 15 30 1B 51 89 E7 06 25 DA CF 13 12 45 B7 5F D7 E5 36 A4 2C 2B 22 37 CB 7E
2:46:49 PM Disconnect request
2:46:49 PM 02:46:49.361 Sent 01 42 30 03 0D 0A
2:47:09 PM 02:47:09.362 Info Closing
2:47:09 PM 02:47:09.484 Info Closed
Gurux.DLMS.GXDLMSException: Connection is permanently rejected. The application context name is not supported.
and this error
"connection is permanently. the application context name is not supported"
I change logical name reference but again receive that error.
and in dlms site write this device work with long name.
can you help me
best regard
Kurumi's picture
LINYANG
Can you read the meter with those settings?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
samira
i can connect but not read
i can connect but not read OBIS
Kurumi's picture
LINYANG
After you have made the connection, select "Refresh" from the "File" menu.
It will read all the objects.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
samira
The connection is not stable.
The connection is not stable,In fact it cant connect completely. If i have used logical name referencing or short name, receive "Connection is permanently. The application context name is not supported" and immediately is disconnected.there is not "Parsing AARE reply succeeded" .The refresh icon is off. I can read sl7000 with your application correctly, but in this meter i think wrong setting manufacture or device window information.is it correct? How can solve "Connection is permanently. the application context name is not supported" error?
Kurumi's picture
LINYANG
Un-check "Logical Name Referencing".
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
samira
I do, but i receive again
I do, but i receive again "Connection is permanently. the application context name is not supported" message.
Kurumi's picture
LINYANG
Can you log in with client address 10? Change that and select "Logical Name Referencing" again.
Your meter returns ciphered data now. You need to decrypt it. You need authentication and block cipher keys for that.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
samira
Thanks for your attention and help.
I log in with client address 10 and select "Logical Name Referencing", but i receive again "Connection is permanently. the application context name is not supported".
Best regard
Samira
Kurumi's picture
LINYANG
Your meter returns ciphered data now. You need to decrypt it. You need authentication and block cipher keys for that. Ask from the vendor is meter supporting only ciphered connections.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
samira
Thanks for your replay and guide. I do it.
Best regard.
Samira
