we are trying to read Landis gyr ZCE Single phase meter through Gurux. Can we read this single phase meters through Gurux ? If yes then what parameters i have to set. Plz help
In GXDLMSDirector Start protocol have IEC option. what is this for ? for which standered ?
and can we read single phase dlms meter with GXDLMSdirector ?
Some meter manufacturers are using IEC 62053-21 as default protocol, but they are also supporting
DLMS. IEC is used to move mode E so DLMS protocol can be used.
IS13779 (IEC 62053:21)
You can't read Landis+Ggyr ZCE with GXDLMSDirector because it does not support IS 15959.
L+G is supporting IS13779 and it's the different standard.
IEC 62053-21
Thanks for reply.
Can we read single phase DLMS meter through GXDLMSdirector ?? and what parameters i have to set ? Same as three phase ??.
GXDLMSDirector
You can read 3 or 1 phase meter using GXDLMSdirector if they are supporting DLMS protocol.
Parameters are depending on the manufacturer.
DLMS issues
Hi, how can I read the MT880 iskraemeco meter using DLMS and transmit the data using GSM/GPRS via DLMSDirector
MT880
Is your meter using static or dynamic IP address?
