By ozkee, 7 December, 2017 Forums Gurux DLMS for Java Hi, When I try to comment to the meter I get this error: Destination addresses do not match. It is 18194. It should be 16. Do you know what could be the cause of this error? Thanks Destination addresses do not match Hi, I believe that you try to make the connection to our example server. Select Gurux to the manufacturer and try again. Now you try to connect with wrong meter type. BR, Mikko Hi Hi, I am trying to connect to lgz meter. I set manufacturer using `GXManufacturer man = items.findByIdentification('lgz');` Is this error connected to `Invalid tag` or `Wrong CRC` error? Thank Destination addresses do not match Hi, Change server address from 16 to 18194. Check four last digits. I believe that those numbers are same as last digits of your meter serial number. BR, Mikko Log in or register to post comments
Thank
