Hi everyone,
I am new to this DLMS ,can anybody help to solve my doubt.
I am reading the billing data from meter using GURUx tool,in the log totally I got 7 commands with responses I am unable to interpret the data from those responses, and i sent the log file below.Please help me to read the data from those responses.
DLMS is very complicated protocol and it can't explain just like this. If you are interested in the protocol, you should get the standard. It's all explained there.
Thank you for the reply,
I am reading Green book and blue book for DLMS protocol ,but I am unable to analyse that data.What I have to do to get familiar with this
hi,
All these values I can get in GXDLMS Director also no....,
I know that data but which value is what I don't know how to analyse that,one value is for particular parameter.
In one Pdf i got the all parameters that includes in billing command but that parameters are not matching with the data I got in GXDLMS director,some parameters are missing
unable to analyse the data from the billing command responses
You can try to use DLMS translator.
https://www.gurux.fi/GuruxDLMSTranslatorInfo
hi,
Make sure that your OBIS code is same. OBIS code is dotted number that describes data you try to read.
Like 0.0.1.0.0.255 is for clock object.
