By Goutam, 18 October, 2017 Forums General discussion Hi, I have multiple dynamic IP meters of different manufacturer. That are using different authentication key. Issue is that which authentication key will use when a dynamic IP meter connect. Query: Is there any option to get the meter serial number before authenticate the connection of dynamic IP meter. Regards, How to authenticate dynamic IP meters with different authenticat Hi, That is the solution. You need to know the meter you are talking to. Ask your meter Logical Device Name and map that to authentication key. BR, Mikko How to authenticate dynamic IP meters with different authenticat Hi, According to your solution, can you please suggest me how I going to read meter Logical Device Name before authentication? Regards, How to authenticate dynamic IP meters with different authenticat Hi, Try to connect without authentication. Read your Logical Device Name: GXDLMSData ldn = new GXDLMSData("0.0.42.0.0.255"); Close connection and make new connection with higher authentication level. BR, Mikko How to authenticate dynamic IP meters with different authenticat Hi, Thank you. Regards, Log in or register to post comments
Thank you.
