L&T DLMS Meter EM101+
7 posts / 0 new
Last post
icebalaji
I am trying to read L&T DLMS Meter EM101+. I am using RJ11 to DB9 cable to get connection between Meter and PC and am sending Dlms snrm frame but not getting any response from meter. But am getting responses from other meters.
So, I have doubt in cable connection, meter I'd, baud rate, parity, stop bit etc.,
Guide me to collect data from meter.
kurumi
kurumi's picture
L+G
Can you read the meter with optical head? Try with 4800 and 9600 8None1. Are you using The same cable with other meters? Are they same brand?
Mikko Kurunsaari
Gurux Ltd
Hermiankatu 6-8 H 33720 TAMPERE, FINLAND
Phone: +358 3 265 1244
Home page: http://www.gurux.org
sateesh
how Communicate with meter
Hi sir,
I am using EM101+ meter from L & T .First i am new to this meter and i don't know how to use this meter ,how to communicate with this meter, which tool is supported to communicate with this meter. I am using RJ11 to DB9 cable to get connection between Meter and PC and I got OBIS codes from L & T team. I tried In hercules setup goto serial and first i setup the baudrate as 9600,parity is even,COM port and press start button, it is showing COM port is opened then i am sending serial no OBIS code frame but not getting any response from meter. But am getting responses from other meters.
I am using GXDLMS Director but in meter setting L & T is not their. I don't know this meter is which category.
If you have any data how to communicate with meters using hercules or GXDLMS Director,GURUX CTT please share .
sateesh
kurumi
kurumi's picture
EM101+ is not support DLMS. It's using IEC1107. You can't read it with DLMS.
Mikko Kurunsaari
Gurux Ltd
icebalaji
Thanks for your valuable reply.
But L&T CC saying that the meter is having DLMS and the firmware version mentioned on the top of Meter box.
harikrishna
How to read obis code of Genus 3 phase category c dlms meter .
Hi Sir,
new to meter field now i am read all obis code of Genus 3 phase category 'c' dlms meter using guruxdlms director software tool please help me,waiting for your kind information.
Thanks & Regards,
hari.
J.harikrishna
kurumi
kurumi's picture
Hi J.harikrishna,
Please, if you have a new question start a new topic.
You can read your meter selecting "Indian Standard" as Manufacturer.
Mikko Kurunsaari
Gurux Ltd
