DLMS Cleint Association View read problem
6 posts / 0 new
Last post
horcsa
I'd like to read Association View using DLMS client, but implementing Simple Reading Meter example not working:
Connection is made by the server but this read not ok.
/// Read Association View from the meter.
readDataBlock(client.getObjects(), reply);
GXDLMSObjectCollection objects = client.parseObjects(reply.getData(), true);
client.getObjects() method is not implemented in the GXDLMSClient.
Can anybody help how to implement this read?
HorCsa
kurumi
kurumi's picture
DLMS Client Association View read problem
This sounds strange. Are you using Eclipse?
Mikko Kurunsaari
Gurux Ltd
Hermiankatu 6-8 H 33720 TAMPERE, FINLAND
Phone: +358 3 265 1244
Home page: http://www.gurux.org
horcsa
I use C# and Visual Studio.
I find only GetObjectsRequest, GetObjectTypes, GetObjectTypes2 in the source of GXDLMSClient.
May I have downloaded wrong version? I've downloaded Gurux.DLMS.Net 2 weeks ago.
HorCsa
kurumi
kurumi's picture
Your example is Java example. With C# you need to use client.Objects , not getObjects.
Mikko Kurunsaari
Gurux Ltd
horcsa
Ok, thanx. I'll try using it. This client.Objects will read all the objects meter offers? Or I have to use GetObjectsRequest()? This is not rally clear for me.
But on the webpage Simple meter reading example if I click on the C# tab the example code also contains GetObjects() method:
ReadDataBlock(client.GetObjects(), reply);
GXDLMSObjectCollection objects = client.ParseObjects(reply.Data, true);
(In my code I tried to use the C# example, but when I copied it to my forum question I missed the tab I've selected.
HorCsa
kurumi
kurumi's picture
Hio,
There is an example available, Gurux.DLMS.Client.Example.Net.
You can use that to read your meter.
ReadDataBlock(Client.GetObjectsRequest(), reply);
Client.ParseObjects(reply.Data, true);
Mikko Kurunsaari
Gurux Ltd
