Difficulty in Landis+gyr E250 to DLMSDirector
6 posts / 0 new
Last post
Snghndh
I m trying to connect to my Landis+Gyr E250 DLMS meter with DLMS director with following settings but getting error
GXDLMSDirector 8.0.1706.1107
Log created 12:44:57 AM
12:45:04 AM Initializing Network connection.
12:45:04 AM Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
12:45:09 AM Failed to receive reply from the device in given time.
at GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters)
Protocol: DLMS
Manufacturer: Landis+Gyr
Authentication: none
Address type: default
Wait time : 5
client address : 10
physical server: 1
Resend Count: 0
Host name - Laptop ip address
Port - 80
proctocol- TCP
Could you please help with this. I have also tried the default setting but it didn't work.
kurumi
kurumi's picture
Are you sure from TCP/IP port? Sent data is correct.
Mikko Kurunsaari
Gurux Ltd
Hermiankatu 6-8 H 33720 TAMPERE, FINLAND
Phone: +358 3 265 1244
Home page: http://www.gurux.org
Snghndh
landis error
I changed the port to 4059 as mentioned in the client program. Then got the following error
Log created 1:19:26 PM
1:19:29 PM Initializing Network connection.
System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it
kurumi
kurumi's picture
No one is listening that port. Can you check this from the meter manual?
You can try with 1000.
Mikko Kurunsaari
Gurux Ltd
Snghndh
Tried port 1000 but same error. Looked at the meter manual but could only see 4059 which does not work.
kurumi
kurumi's picture
Check is your TCP/IP module enabled. Problem is that your meter's TCP/IP socket is not working.
Mikko Kurunsaari
Gurux Ltd
