By atulsawant, 3 August, 2017 Forums General discussion Dear sir, which OBIS code used for kwh rollover event? OBIS code Hi, You should read your meter and check what OBIS code thay are using. Standard OBIS codes you can found from here: http://www.gurux.fi/GuruxDLMSTranslator Select "OBIS code" tab. BR, Mikko Log in or register to post comments
OBIS code
