Gurux Listen Service Issue
4 posts / 0 new
Last post
keenangeorge
Hi Gurux
When initializing a connection with Listening Service on Hexing meter i set the parameters to the following.
Client.UseLogicalNameReferencing = true;
Client.Authentication = Authentication.High;
Client.Password = GXDLMSTranslator.HexToBytes("000000000000");
Client.ServerAddress = 1;
Client.ClientAddress = 1;
Client.InterfaceType = InterfaceType.WRAPPER;
Then i get the following error.
Destination addresses do not match. It is 16. It should be 1.
When i change the settings to:
Client.ClientAddress = 16;
I get the following error.
System.Exception: Secure connection is not supported.
Trace
<- 5:32:52 PM 00 01 00 10 00 01 00 40 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 0D 0E 13 58 73 5A 48 61 21 18 73 35 61 07 1B 65 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF
-> 5:32:53 PM 00 01 00 01 00 10 00 12 DD 10 00 00 00 00 30 31 34 32 36 34 36 33 31 32 31 30
Regards
kurumi
kurumi's picture
Your meter is using ciphering (secured connection). You must use GXDLMSSecureClient instead of GXDLMSClient and set correct secured values.
Mikko Kurunsaari
Gurux Ltd
Hermiankatu 6-8 H 33720 TAMPERE, FINLAND
Phone: +358 3 265 1244
Home page: http://www.gurux.org
keenangeorge
Thanks Mikko
GXDLMSSecureClient Client = new GXDLMSSecureClient(true, 0x10, 1, Authentication.High, null, InterfaceType.WRAPPER);
Client.Password = GXDLMSTranslator.HexToBytes("00000000");
Now i get the below error
8/1/2017 4:45:29 PM System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
Parameter name: cryptedData
<- 4:48:00 PM 00 01 00 10 00 01 00 40 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 4A 64 28 33 39 33 2C 3A 66 71 23 75 3D 47 23 6B BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF
-> 4:48:02 PM 00 01 00 01 00 10 00 12 DD 10 00 00 00 00 30 31 34 32 36 34 36 36 36 38 31 30
<- 4:48:38 PM 00 01 00 10 00 01 00 40 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 30 6A 5F 11 0B 05 33 4F 39 46 6A 6B 5B 4E 29 71 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF
-> 4:48:39 PM 00 01 00 01 00 10 00 4C 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 34 43 45 44 37 31 43 45 37 32 43 30 34 34 34 32 BE 0F 04 0E 08 00 06 5F 1F 04 00 00 18 1F 01 00 00 07
<- 4:48:39 PM 00 01 00 10 00 01 00 0D C0 01 C1 00 01 00 00 60 01 00 FF 02 00
-> 4:48:40 PM 00 01 00 01 00 10 00 12 DD 10 00 00 00 00 30 31 34 32 34 39 38 34 36 32 37 31
If i however just leave the tool to run the make the connection and read all values.
Any idea why this is happening.
Regards
Keenan George
kurumi
kurumi's picture
Hi Keenan George,
Your secure settings are not set. Set them.
Client.SystemTitle = ;
Client.BlockCipherKey = ;
Client.AuthenticationKey = ;
Mikko Kurunsaari
Gurux Ltd
