Hi Sir
4 posts / 0 new
Last post
erdeepakcs
Hi Sir
I have off the RTS and DTR for communication in serial port, but when it is sending command on serial port it gets on.
gxSerial1.RtsEnable = gxSerial1.DtrEnable = false;
BR
kurumi
kurumi's picture
RTS and DTR
If you are using C# version, RtsEnable and DtrEnable methods are only wrapper for .Net version component.
Check that you have latest version from serial port drivers. This usually helps.
Mikko Kurunsaari
Gurux Ltd
Hermiankatu 6-8 H 33720 TAMPERE, FINLAND
Phone: +358 3 265 1244
Home page: http://www.gurux.org
erdeepakcs
hi sir
i didn't get your point sir, can you explain it.
What driver should i use for this ?
thanks
Deepak
Deepak
kurumi
kurumi's picture
RTS and DTR
Hi Deepak,
You should check that your serial port drivers for Windows are latest.
We don't make anything when you enable or disable RTS or DTR.
Mikko Kurunsaari
Gurux Ltd
