Event notification api for java
6 posts / 0 new
Last post
yatingarg168
Has event notification not been implemented for DLMS/COSEM? If not is there any other way to push events like Meter Power Failure, SAX SWELL etc to the client?
Yatin
kurumi
kurumi's picture
You can send Push events using generatePushSetupMessages-method. You should check gurux.dlms.push.listener.example. In Push message you can send any COSEM object data you like.
Mikko Kurunsaari
Gurux Ltd
Hermiankatu 6-8 H 33720 TAMPERE, FINLAND
Phone: +358 3 265 1244
Home page: http://www.gurux.org
yatingarg168
Thanks for your reply. generatePushSetupMessages method calls generateDataNotificationMessages method which uses DATA_NOTIFICATION(id=15) command. I want to send EVENT_NOTIFICATION(id = 194]) command which is not listed in Command class itself.
Yatin
yatingarg168
Any update on above?
Yatin
kurumi
kurumi's picture
We have added Event notification and InformationReport services. We try to release it on this week.
Mikko Kurunsaari
Gurux Ltd
yatingarg168
Great.. Thanks :)
