I am using the code from GitHub and able to connect and read dlms meter data when I run the client on Windows.
Same code when I tried to run on Linux, the connection is successful, but when reading data block it's giving error- The Authentication Name not supported. I am using Low Authentication with password and passing the details as argument to Java client class.
DLMS Client on Linux | Not able to read data
You need to change UseLogicalname.
If you are using ANSI C++ it's first parameter (boolean).
Thanks Mikko,
Thanks Mikko,
I was able to resolve by launching jar with sudo.
