Landis+Gyr E650 setup
4 posts / 0 new
Last post
rubinp
If I have an out-of-box unit, can I use tcp/ip to connect using GXDLMSDirector with the correct IP:port setting?
kurumi
kurumi's picture
Shortly, YES.
You need Communication unit CU-E20 / E21 / E22.
If you have that, you need to enable it.
If you can access your meter example using optical head, change Logical Device address from 0 to 1 and
you can check your communication module settings. Example listening port number.
Mikko Kurunsaari
Gurux Ltd
Hermiankatu 6-8 H 33720 TAMPERE, FINLAND
Phone: +358 3 265 1244
Home page: http://www.gurux.org
rubinp
Thanks for the reply. I will be starting a project soon using the L+G E650.
rubinp
Connecting to L+G E650
Hi again..
I have an L+G E650 test unit, and am attempting to setup communications.
I do not have the serial interface, so will have to use TCP/IP only.
The unit was configured with an IP address of 192.168.110.10.
When connecting, I get the following error message:
"No connection could be made because the target machine actively refused it"
Where am I going wrong?
