Dear sir,
I am using following settings to transfer the C to S challenge.
System title-4D4D4D0000000001
Invocation counter-00000001
Block cipher key-0000102030405060708090A0B0C0D0E0F
Authentication key-D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF
Challenge-k56iVagY
Tool gives error "Invalid system title"
What can i do?
can you please suggest which changes are required ?
System title must be 8 bytes long. If you are giving this from GXDLMSDirector make sure that ASCII checkbox is not set. This same is for Authentication key and Block cipher key.
Dear Sir,
