In GXDLSMDirector, if I choose Tools->Manufacturers->[some maker]->edit, the Addressing Authentication selection box only shows the subset of authentication types the manufacturer supports. There doesn't seem to be a way to add a new authentication type to a manufacturer through the GUI. I have to exit its XML file, and add the new authentication type there.
Once the new authentication type is added in the XML, it can be configured through the GUI
You are right. At the moment authentication types must modify from xml.
I'll add this to work list, but priority is low because this is not done often.
Cannot add new authentication types to a manufacturer
