I am trying to write clock object (0.0.1.0.0.255) using GURUX DLMSdirector.
Reading of clock object is right. when reading the tool shows accurate reading i.e. today's date-time.
but when i am trying to write object then it shows the error String was not recognized as a valid DateTime. .
why this happen? how to overcome this error?
is there any other procedure or setting required to write the clock object?
setting in tool menu is Attribute: 2.Type:OctecString.UIType:DateTime.
clock write
Dear sir,
Usually there is date and time in clock. In your clock there is only time part. Can you send trace from write message, so we can check that also.
