Having problem in connecting multiple GPRS(TCP/IP) meters.
18 posts / 0 new
Last post
Nitin Sethi
Nitin Sethi's picture
We are using TCP/IP protocol. And for single meter having dynamic ips with previous version of Gurux net api, I am able to read data asynchronously. But now for multiple meters i am able to capture multiple socket connections but not able to read data. So please tell me about that.
issue followed by this link: http://www.gurux.fi/node/5900
Nitin Sethi
Kurumi's picture
I have few questions.
1. What version you are using now (Gurux.Net.dll)?
2. What was your previous version?
3. Can you read single meter with new version?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Nitin Sethi
Please find the answers as per your questions:
1.) We don't know the exact version because we are using the development kit of gurux.net for java. But in those apis ListenerThread class was not available and because of this we were not getting List<Socket> connection But now we are getting multiple clients socket connections.
2.) And with new version we are not able to read even single meter but with earlier apis we are able to read.
Nitin Sethi
Hi Kurumi,
I have been waiting for you answers for previous posted question. Please let me know about it.
Kurumi's picture
You can see version if you select pom.xml. You can get version from version tag.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
GABZZsoft
Could you kindly walk me through on how to read multiple GPRS meter with Dynamic IP addresses
Kurumi's picture
If you have a new question, please, create a new topic. You should read this to get started.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
GABZZsoft
The meter has been able to connect to the server, and i can read the meter from the OnClientConnect method but unable to read the meter from another method after connection has been established. Kindly help me on how to go about this?
Kurumi's picture
You need to read all data before you release the connection. Is connection established correctly?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
GABZZsoft
Connection has been established and am able to read all data usin the OnClientConnect listenner. My question is, what if i want to read multiple meters upon the occurrence of an event, say read clock upon a button click? how do i go about it?
Kurumi's picture
Are the meters behind the DC or is each meter making own connection?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
GABZZsoft
Each meter is making it's own connection. Not making using of a DC
Kurumi's picture
When meter makes connection OnClientConnect method is called for each meter. So you start own client instance for each meter and read needed information. After you have read data, you release the connection.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
GABZZsoft
I want to keep the connection and be able to read either of the meters, using the ip address and port of the connected meter to read it upon clicking a button. I would keep the socket connection active
Kurumi's picture
If you want to keep the connection up, you need to send keep-alive or meter will close the connection after inactivity timeout. In that case, don't call release or disconnect.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
GABZZsoft
Thanks you for you support. You don't seem to get my question.
GABZZsoft
say i want to control the relay of a connected meter, how do i do it upon making an event occur...
Kurumi's picture
Hi GABZZsoft,
Please, create new topic. Now I have mixed your and Nitin 's questions.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
