Holley Meter DTSD545 successfully sending its heartbeat after specified interval by using Gurux.DLMS.Server.Example.Net on my server. Now I want to read some meter parameters using OBIS codes (Meter supports OBIS codes).
Kindly suggest me the right way and lines of code to read parameters.
Meter is on static ip and SIM ip is not static.
Reading a Simple Parameter using OBIS
After meter makes connection you can try to send AARQ message to the meter.
If meter replies it's easy to continue.
Send AARQ message to meter
How to send AARQ message to meter in Gurux.DLMS.Server.Example.Net ?
Kindly guide me.
You should use Gurux.DLMS.Client.Example.Net to communicate with the meter.
