The online DLMS<->XML translator on the Gurux web site uses an XML schema that seems very different from the one in the DLMS specification. Is there a plan to make the translator conformant?
Select "Standard XML" checkbox. That will produce standard XML. Also it might be good to select PDU only. It will remove HDLC or WRAPPER frames in message mode.
DLMS translator
