Hi, I'm newby with meters. Im tryng reading a meter Itron ACE6000. I can read an OBI CODE in this way:
GXCommunicate com = null;
com = getManufactureSettings(args);
GXDLMSRegister it = new GXDLMSRegister("1.1.32.7.0.255");
com.initializeConnection();
Object val= com.readObject(it, 3);
val= com.readObject(it, 2);
But I have problems reading Load Profile:
GXDateTime date1 = new GXDateTime(2016,7,15,6,0,0,0);
GXDateTime date2 = new GXDateTime(2016,7,15,7,0,0,0);
GXDLMSObject clock = new GXDLMSObject();
clock.setLogicalName("0.0.1.0.0.255");
GXDLMSProfileGeneric pg = new GXDLMSProfileGeneric("1.0.99.1.0.255");
pg.setSortObject(clock);
Object[] vals = com.readRowsByRange(pg, date1.getValue(), date2.getValue());
The meter response is:
Frame ID do not match.
gurux.dlms.GXDLMSException: Access Error : Device reports scope of access violated.
After execute
byte [][] val = null;
val = com.read(pg,2);
val contains the following:
[126][-96][25][1][1][50][-28][78][-26][-26][0][-64][1][-127][0][7][1][0][99][1][0][-1][2][0][81][68][126]
This is:
7E A0 19 01 01 32 E4 4E E6 E6 00 C0 01 81 00 07 01 00 63 01 00 FF 02 00 51 44 7E
Is this response fine? It's necesary set objects to read with Generic Profile:
o = new GXDLMSObject();
o.setLogicalName("1.1.5.29.0.255");
o.setObjectType(ObjectType.REGISTER);
pg.addCaptureObject(o, 2, 2)
Hi, I tried what you said but the meter response is the same:
when I execute val = cl.read(pg, 3);
Val --> 7E A0 19 01 01 32 E4 4E E6 E6 00 C0 01 81 00 07 01 00 63 01 00 FF 03 00 89 5D 7E
after that, I execute val = cl.read(pg, 2);
Val --> 7E A0 19 01 01 54 D4 48 E6 E6 00 C0 01 81 00 07 01 00 63 01 00 FF 02 00 51 44 7E
My code is:
public static void main(String[] args) {
GXDLMSClient cl = null;
PrintWriter logFile = null;
byte[][] val;
GXDLMSObject it = null;
try {
logFile = new PrintWriter(new BufferedWriter(new FileWriter("logFile.txt")));
cl = createClient(args);
cl.setUseLogicalNameReferencing(true);
if (cl == null) {
return;
pg.setCapturePeriod(15);
pg.setProfileEntries(100);
pg.setSortMethod(SortMethod.FIFO);
GXDLMSObject[] o = new GXDLMSObject[8];
o[0] = new GXDLMSObject();
o[0].setLogicalName("0.0.1.0.0.255");
o[0].setObjectType(ObjectType.CLOCK);
pg.setSortObject(o[0]);
//Add Columns to ProfileGeneric. It's not necesary
pg.addCaptureObject(o[0], 2, 0);
o[1] = new GXDLMSObject();
o[1].setLogicalName("1.1.1.29.0.255");
o[1].setObjectType(ObjectType.REGISTER);
pg.addCaptureObject(o[1], 2, 1);
o[2] = new GXDLMSObject();
o[2].setLogicalName("1.1.5.29.0.255");
o[2].setObjectType(ObjectType.REGISTER);
pg.addCaptureObject(o[2], 2, 2);
o[3] = new GXDLMSObject();
o[3].setLogicalName("1.1.8.29.0.255");
o[3].setObjectType(ObjectType.REGISTER);
pg.addCaptureObject(o[3], 2, 3);
o[4] = new GXDLMSObject();
o[4].setLogicalName("1.1.13.27.0.255");
o[4].setObjectType(ObjectType.REGISTER);
pg.addCaptureObject(o[4], 2, 4);
o[5] = new GXDLMSObject();
o[5].setLogicalName("1.1.32.27.0.255");
o[5].setObjectType(ObjectType.REGISTER);
pg.addCaptureObject(o[5], 2, 5);
o[6] = new GXDLMSObject();
o[6].setLogicalName("1.1.52.27.0.255");
o[6].setObjectType(ObjectType.REGISTER);
pg.addCaptureObject(o[6], 2, 6);
o[7] = new GXDLMSObject();
o[7].setLogicalName("1.1.72.27.0.255");
o[7].setObjectType(ObjectType.REGISTER);
pg.addCaptureObject(o[7], 2, 7);
//ACE6000 is not fully support DLMS. Reading profile generics is made in custom way.
//Easiest way is if you read all data from the buffer
convertToString(val[0]);
for (int i = 0; i<val.length;i++) {
convertToString(val[i]);
System.out.println( " Value of index "+i+": " + convertToString(val[i]));
} catch (Exception e) {
System.out.println(e.toString());
} finally {
if (logFile != null) {
logFile.close();
try {
// Disconnect.
if (com != null) {
com.close();
} catch (Exception Ex2) {
System.out.println(Ex2.toString());
System.out.println("Done!");
Can not read Load Profile from ACE6000
com.read(pg, 2);
Thanks. But in the example
Thanks. But in the example you posted:
com.read(pg, 2);
pg is an object of class GXDLMSProfileGeneric?
Or you mean I have to read every column of the Profile Generic in this way?
After execute
After execute
This is:
Profile Generic
Hi Carlos,
I used your example above. pg is:
Read is call only for the profile generic object, not each column.
Profile Generic
Hi Carlos,
Your data seems to be ok. You should read attribute index 3 to get columns before this.
com.read(pg,3);
Problems to get Load Profile
My code is:
byte[][] val;
try {
if (cl == null) {
return;
} finally {
logFile.close();
try {
// Disconnect.
if (com != null) {
com.close();
