Gurux sampleclient not reading profilegeneric buffer and capture_objects
2 posts / 0 new
Last post
mansour
I'm testing the sampleclient (java) you provided for reading a profilegeneric object from GuruxDLMSServerExample in this way :
1) I launch the sample DLMS Server with this configuration :
GXDLMSServerSN_47 SNServer = new GXDLMSServerSN_47();
SNServer.Initialize(4060);
--> In GXDLMSProfileGeneric instance I see that the attribute "captureObjects" is correctly populated with clock and register object :
pg.addCaptureObject(clock, 2, 0);
pg.addCaptureObject(register, 2, 0);
2) When the GXProfileGenericUpdater runs it adds values to buffer attribute of GXDLMSProfileGeneric instance
3) When I run sampleclient with this params :
GXDLMSClient dlms = new GXDLMSClient(false, 16, 1, Authentication.LOW, "password", InterfaceType.WRAPPER);
--> in GXCommunicate.readProfileGenerics() I can see that "entriesInUse" and "entries" are correctly read but attributes "buffer" and "capture_objects" from "pg" instance that are read on client side are always empty...
--> Can you please complete the sample in order to see how to properly read the attributes "buffer" and "capture_objects" from a ProfileGeneric object ?
Mansour
Kurumi's picture
sampleclient
Hi Mansour,
I'm so sorry that I have not answer for this question. For some reason I have not noticed it.
Someone reply spam for this and I noticed it accident.
Is this problem still active or have you solved it?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
