Hi anyone tried CPP client(https://github.com/Gurux/Gurux.DLMS.cpp) example? I need little more info on how to run makefiles in LINUX.
I tried compiling the code in VisualStudio2015,, i successfully compiled and i am starting to read from Landis, i am getting "GetObjects failed" error. I suppose i have given all manufacturer specific parameters for "CGXDLMSClient cl()". Help me out?
Hi, sorry for the delay. I fact i have given a mail, no response, thats why i am here.
If i want to send SNRM frame as
(7e a0 23 00 02 04 01 41 93 98 f2 81 80 14 05 02 08 00 06 02 08 00 07 04 00 00 00 07 08 04 00 00 00 07 b3 c6 7e ), how can i proceed?
Could you please explain how code is framing the SNRM
I am using LNG E250 Indian meter.
Here is the trace:
<- 12:48:03 7E A0 0F 03 41 93 82 81 81 80 FD 06 01 3E F7 E3 7E
SNRMRequest failed 252
InitializeConnection failed Data send failed..
We are not supporting Window size setting at the moment in SNRM message.
Usually this is an option and you do not need to send them.
Do you have special need for this?
I am using Ubuntu
I have given this:
if ((ret = comm.Open("/dev/ttyUSB0", false)) != 0)
Verified with putty also.
These settings were used in GuruxDirector: (Winodws 10)
Manufacturer : Indian standard
Logical Name Referencing : checked
Start protocol: DLMS
Media : Serial
Password : XXXXXXXXX
ASCII : Checked
Wait time : 7
Client Address : 20
Address Type : Default
Physical Server : 1
Logical Server : 0
Settings:
Serial port : COM1
Use Maximum Baud Rate : 9600
We have made makefile for linux environment. You should go development folder and create lib and obj directories. Then run make. gurux_dlms_cpp static library is made.
For Client example you should also create bin and obj -directories. Change Host name, port and DLMS settings for example. Run make and you are ready to test.
I'm trying to run ClientExample with arguments (like Java), could you give me more information about it?
Gurux.DLMS.cpp client example issue
First you should go development folder and run make. Just simply type make to cmd line.
What kind of error you are receiving? Can you send trace to me by email? Do not send it to the forum, because it might be huge.
SNRM failed
Here is the trace:
SNRM
SNRM failed
Same thing with another indian meter also
<- 17:18:09 7E A0 07 03 21 93 0F 01 7E
SNRMRequest failed 252.
But this time it is working with GURUXDirector
Any suggestions?
SNRM failed
Please, create new topic if you have new question. It's easier to answer.
Are you using Linux or Windows? Check your serial port settings.
I am using Ubuntu
I am using Ubuntu
I have given this:
Media : Serial
ASCII : Checked
Wait time : 7
Client Address : 20
Physical Server : 1
Logical Server : 0
Settings:
Serial port : COM1
With these i could read all available objects
Anything i am missing in client program (CPP)?
SNRM failed
Usually this is because you don't have access right to the serial port.
Have you try this using root or sudo?
Before start
I have done these two steps for Linux:
Morphheus
cpp client
Hi Morphheus,
Command line parameters are same for java and C++.
