New Obis Code
5 posts / 0 new
Last post
m2m
New Obis Code
Hello I 'm trying to retrieve the time profile of the active energy injected and withdrawn . Among the Obis codes in the Director I was not able to try a find . I wanted to load other codes based on the SL7000 Manual . I went on the new button Obis I chose generic profile but the program does not allow me to upload my code. I can add their Obis by program or you can do it only you to code?
Thank you
Kurumi's picture
New Obis Code
Select Refresh from File menu. That will retreave all objects from the meter.
OBIS code description might be wrong, because SL 7000 is using own OBIS codes, not standard one.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
m2m
Ok Thanks
Ok Thanks
dhirajthaokar
please give me sample code for secure apex meter
i am getting
param string [S=/dev/ttyUSB0, c=16, s=1, i=IEC, g=1.2.0:1, t=Info]
0
Device is IEC
Authentication: None
ClientAddress: 0x10
Connection Establish....
Kurumi's picture
Apex meter
Please, create a new topic if you have new question.
What is model of the meter?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
