I'm also trying to connect to an EDMI Atlas Mk10A.
I'm trying to connect via serial port. This meter has a "Type 7" serial port, with power and dual RS232. The "lower" serial port is the SCADA port. The port numbe TB1 has pins 9 and 8 for RX2 and TX2 so I've wired these into pints 5 and 6 (of the RJ45 plug).
Do I need to cross the TX to the RX?
Which are the correct settings to use to connect the meter?
Currently I get the message "Failed to receive reply from the device in a given time".
I have also tried the "Landis+Gyr" settings, with start protocol=DLMS.
EDMI METER
What is the model of the meter you want to read?
EDMI MK6N Genius and EDMI
EDMI MK6N Genius and EDMI MK10A. Please your guidance.
Thanks!
EDMI Mk6N Genius and Mk10A
EDMI Mk6N Genius and Mk10A Atlas. Please your guidance
We've tried to connect meter
We've tried to connect meter Mk6N Genius, but appear warning "
Failed to receive reply from the device in given time". any solution for this case?
May give me your email address?
Thanks Before.
Warm Regards
Finally I got information. I hope this helps you.
One our community member informs me that you can try with Landis+Gyr settings.
Just select starting protocol to DLMS.
Please, let me know if you succeeded.
Connect EDMI meter with Gurux Device Suite Director
What is the setting for connecting MK10E Altas meter?
Any Printscreen or video to reference?
Thank you very much
Connect EDMI meter
We do not have MK10E Altas here in our office.
So we can't make video for this meter.
Connecting to Mk10A
Connecting to Mk10A
Check if there are instructions in your meter documentation.
