By baycan, 9 September, 2014
I have a board which has msp430 MCU. And TI has a DLMS COSEM Library. I embedded this library on to my board. So I was need a client software. When I was trying to communicate with Gurux and my board I had an error like "failed to receive reply from the device in given time".
So I checked my code if it has a interrupt when gurux request and I could see there was an interrupt. But My board was not answer. I wonder if because of my Device Properties? Couse ı dont know which manufucterer, Client address, .. something like this configurations .
Is there anyone that already tried that?
First of all thanks for replying. I solved my connection problem. But there is another problem for me. When I connect in High authentication mode, I can connect my device but when I tried to read objects I got an error message which says "GetObjects failed.Access Error:Device reports scope of access violated.". Can you tell me what is wrong of my sistem ?
i have the library code v4.6 but some files are missing it showing skip or use the file can u send me the full code to my mail
[Email address removed by admin]
Texas Instruments DLMS stack with Gurux
If your meter answers nothing reason for this it that server or Client address is wrong.
You can try with those:
Client ID = 0x21 (In GXDLMSDirector value is 10).
Server ID = 0x3 (In GXDLMSDirector physical address is 1 and logical address is 0).
Hi , First of all thanks for
Hi ,
best regards.
Sorry for slow reply. I miss this post.
Do you have any information is Texas instrument using MD5 or SHA-1 in High authentication mode?
TI'S EVM failed to connect in the given time WITH GURUX
sir,
i m trying to connect the evm with dlms/cosem library but after the connection of UART points,i stuck at the gurux failed to reply message
how to connect ti's EVM and what are the client and server address
Try to connect with GXDLMSDirector. Select TI as a manufacturer. Client address is 0x10 and Physical Server address is 1.
sir can you mail me the full library code
can i mail you sir so u can check all files are correct or not
can i mail you sir so u can check all files are correct or not ,can i sir
I'm sorry, but you need to ask those missing files from TI.
