Thanx for reply and additional information about this model.
I have found some presentation from this year, they started to support DLMS/COSEM.
M&M spec is not accessible?
We are not supporting M&M at the moment because no on of clients is using M&M meters. We will add support if our clients buy M&M meters and need support.
Basically you are right, but as I told before we are not supporting M&M and I do not know much from that protocol.
Long time no see. Hope you are doing safe and well.
I have installed latest version of GuruxDLMSdirector and connect to ENEL GIST i have. I created new manufacturer using Italian standard template , just changing manufacturer label to EDi. Connecting via serial port. This is from LOG file
18:08:14 Initializing serial connection.
18:08:15 IEC Sending:/?!<CR><LF>
18:08:16 HDLC received: /EDi5134E5B21xxxxxxxx<CR><LF>
18:08:16 Maximum BaudRate is set to : 300
18:08:16 BaudRate is : 300
6:08:16 PM Moving to mode E.
06 32 30 32 0D 0A
6:08:20 PM Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
18:08:25 Data send failed. Try to resend 1/3
18:08:30 Data send failed. Try to resend 2/3
6:08:35 PM Failed to receive reply from the device in given time.
18:08:35 Disconnect request
6:08:35 PM Send Disconnect request.
7E A0 07 03 21 53 03 C7 7E
18:08:40 Data send failed. Try to resend 1/3
18:08:45 Data send failed. Try to resend 2/3
6:08:50 PM Failed to receive reply from the device in given time.
Important to say is that I switch Start protocol from DLMS to IEC. afterwhile Error appears on screen.
It is ENEL Distibuzione Italy company. Smart meter is GIST model, three phase. Also meter and mores protocol is in use here, So that could be a problem.
I thought if handshake passed and meter returns serial number for further communication maybe some settings are problem. I turned on also Verbose mode and it seems that after command moving to mode E sent to meter communication parameters are changed and meter returns zeros.
--part of log
7:05:12 PM Moving to mode E.
06 32 35 32 0D 0A
19:05:12 07:05:12.289 Sent 06 32 35 32 0D 0A
19:05:14 07:05:14.293 Info Closing
19:05:14 07:05:14.406 Info Closed
19:05:14 07:05:14.406 Info Opening
19:05:14 07:05:14.406 Info Serial Port Settings: Port Name: COM4 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Flow Control: None Eop: None
19:05:14 07:05:14.434 Info Open
19:05:14 07:05:14.490 Received 00
19:05:14 07:05:14.504 Received 00
ENEL GIST model
If I remember right They use Telegestore meters in that project and
protocol is Meters And More. (http://www.metersandmore.com/tag/protocol/)
We are not supporting Meters And More at the moment. We will start supporting Meters And More if our customers need that.
ENEL GIST model
Regards.
Cavaser
Enel GIST
This is interesting. I have not heard anything from this. Please, let me know if you have any new info from this.
I was able to download M&M specs.
Enel GIST
I have found that about DSLM on official site of M&M. You can download presentation in Geneve, from March if remember well.
I thought about protocol M&M specification. Is this document opened and can be used?
In case that Handshake passed and meter returns values as expected, what does mean that? Meter could be read ?
Regards.
Enel GIST
Hi Cavaser,
hi!, any news about this?.
Hi Mikko, jfrez,
Hi Mikko, jfrez,
06 32 30 32 0D 0A
Model is ENEL GIST 2013 also from Italy.
Thanx for any help.
I believe that your meter is not supporting DLMS. Check is there a DLMS label on the cover of the meter.
--part of log
06 32 35 32 0D 0A
Regards
If your meter is using Meter&More, then I can't help you with your meter.
You need to ask this from someone else.
