By fbarenghi, 11 February, 2014 Hi. I am using GXDLMDirector to communicate with a meter. Reading special days form the meter I found a bug: the meter sends its table correctly but GXDLMDirector always displays its own default data. The problem is into the GXCommon.cs module, decoding the "Date" type (from line 705): the decoded data are not written into the returned object. A solution, in my opinion, is to change the code as for the data type "Time": else if (type == DataType.Date) { if (size 5) //If there is not enought data available. { pos = 0xFF; return null; } DateTimeSkips skip = DateTimeSkips.None; //Get year. int year = GXCommon.GetUInt16(buff, ref pos); if (year == 0xFFFF) { skip |= DateTimeSkips.Year; year = DateTime.MinValue.Year; } //Get month int month = buff[pos++]; if (month == 0xFF || month == 0xFE || month == 0xFD) { skip |= DateTimeSkips.Month; month = 1; } int day = buff[pos++]; if (day 0 || day > 31) { skip |= DateTimeSkips.Day; day = 1; } //Skip week day int DayOfWeek = buff[pos++]; //If day of week are not used. if (DayOfWeek == 0xFF) { skip |= DateTimeSkips.DayOfWeek; DayOfWeek = 1; } GXDateTime dt = new GXDateTime(year, month, day, 0, 0, 0, 0); dt.Skip = skip | DateTimeSkips.Hour | DateTimeSkips.Minute | DateTimeSkips.Second | DateTimeSkips.Ms; return dt; } Best regards Franco GXCommon.cs Hi Franco, Thank you very much for let us know this issue. We fixed this and new versions are available at GitHub. BR, Mikko Log in or register to post comments
GXCommon.cs
Hi Franco,
