By mafrmota, 7 November, 2013
hello,
I'm trying to communicate with a meter ZMD310AT through optical port and gives nothing.
-I have a head with ligei otica connected directly to a COM port and nothing.
-Already ligei attractions is the converssor USB/RS232 and also nothing
I have used a head-otica USB and nothing.
I just got results when I used the communication through the net.
Can you give me the settings for the parameters via serial communication
here log comunication;
Log created 10:25:11
10:25:19 Initializing serial connection.
10:25:19 HDLC sending:/?!
10:25:21 HDLC received: /LGZ4\2ZMD3102400.B31
10:25:21 BaudRate is : 4800
10:25:21 Moving to mode E.
06 32 34 32 0D 0A
10:25:22 Disconnect request
10:25:22 Failed to receive reply from the device in given time.
em GXDLMSDirector.GXDLMSDevice.InitializeConnection() em C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:line 345
em GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) em C:\Projects\GXDLMSDirector\Development\MainForm.cs:line 948
I've tried everything
tested various speeds, times(like you said 5s and another) and nothing like you said.
With the connection type "net" all ok
with serial connection I can not successfully
The log file ;
14:21:29 Initializing serial connection.
14:21:29 HDLC sending:/?!
14:21:30 HDLC received: /LGZ4\2ZMD3102400.B31
14:21:30 BaudRate is : 4800
14:21:30 Moving to mode E.
06 32 34 32 0D 0A
14:21:32 Disconnect request
14:21:32 Failed to receive reply from the device in given time.
here log comunication; Log
06 32 34 32 0D 0A
serial communication ZMD310AT
Your parameters seems to be right. Try to set waittime bigger.
I believe it's 1 second. Try with 5 second. Handskaking might sometimes take time.
I've tried everything tested
The log file ;
06 32 34 32 0D 0A
This is strange. Are you using Java or .Net client?
Have you try with GXDLMSDirector?
With some meters handshaking is little problematic because baudrate is changed on the fly, byt L&G meters usually work fine.
BTW: Try to set start protocol to DLMS with GXDLMSDirector.
