I'm trying to connect to a meter but it's not on the list of manufacturers to select. How should I go about connecting to a meter or dcu from a different manufacturer?
Please, create a new topic when you have a new question. You can try to select Gurux as a manufacturer or create a new topic where add name of the manufacturer and I'll help you to find correct settings.
GetObjects failed. Failed to receive reply from the device in gi
What meter you are using? It is not work correctly.
Length of the frame is wrong and there are some other issues also.
meter objects
Hi lhein,
Hi lhein,
