There is no gurux folder under the commonfiles (either usual or Prgram Files (x86) folder).
I renamed the existing Gurux.Net.dll in the C:\Program Files (x86)\Gurux\GXDLMSDirector 7.0 Community Edition folder and then copied the newly downloaded dll to that folder.
When I try to connect I get exactly the same error message.
Using IPv6 addressing
Hi Adrian,
We have fix this. You can download new version from
http://www.gurux.org/Downloads/Gurux.Net_7.0.6.1.dll.zip
Unzip it and copy it to the C:\Program Files\Common Files\Gurux\GXCom folder.
We will continue tests are it is relased with next releases.
Please, let us know if you find anything.
Thanks for the prompt support.
Your change seemed to make no difference for me.
I am using a Win7 64 bit OS.
Adrian Jones
Dummy
We found the problem and fixed it.
Download new dll here:
Note! You must check "use IPv6" from settings dialog.
We are unable to open the below link
Janardhan
Hi Janardhan,
Hi Janardhan,
You can get the latest version from GitHub.
https://github.com/Gurux/Gurux.net
