By fbertoli, 18 March, 2011
preliminary remarks: I'm a newer regarding C#programming.
I'm using such sample just to for testing purposes and I would like to know in which format I have to write sending data if the hex checkbox is selected.
I try several choices, i.e. 0x10 0AH etc, but every time the format seems to be wrong. Because of the conversion has been done using GXCom methods could you explain the required format?
thanks in advance for your answer.
New version of GXNet tomorrow
Thanks, fbertoli, for pointing this out!
Our developers took a look at the sample, and indeed there was a flaw. It is fixed now, and we'll be able to put the new version out tomorrow.
Thank You, fbertoli, for taking the time, and reporting this.
Gurux developers
