By ajaywazir, 8 September, 2010
We installed the released version of DLMS director.
Tried to use LandisMeter type in LN mode using TCP/IP.
It does not connect since there is no way we can add server id and client id.
It does not seem to load the same from obx files?
Ajay
Thank you for your comment.
We have talk lot of changing client and server IDs.
At this moment, you can use GXDLMSDirector only with Landis+Gyr and Iskraemeco meters.
We are updating new version that can work with other manufacurers devices in next week.
I believe that problem in your case is that you have changed values to .obx file. When connection to the device is made, GXDLMSDirector try to identify device using IEC 62056-21 command "/?!". Application returns something else that LGZ. Now "Unknown Manufacturer" exception is thrown, because GXDLMSDirector do not know your device type.
Best Regards,
Changing client and server IDs
