Hello
I am using your Atmel code for ATSAME54 Xplained pro board. My code compiled and debugged it connected to meter
TX: 7E A0 07 03 41 93 5A 64 7E
RX: 7E A0 1E 41 03 73 8E 7F 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
but following code is not exicuting
gxClock clock;
ret = cosem_init(&clock.base, DLMS_OBJECT_TYPE_CLOCK, "0.0.1.0.0.255");
//Initialize connection.
ret = com_initializeConnection(&con);
return ret;
Read clock.
ret = com_read(&con, &clock.base, 2);
return ret;
When I run It I got Following Reply
TX: 7E A0 19 03 41 10 2A BF E6 E6 00 C0 01 81 00 08 00 00 01 00 00 FF 02 00 65 D7 7E
RX: 7E A0 10 41 03 30 53 A1 E6 E7 00 0E 01 03 02 94 A8 7E
HI,
Could you please help me how can I do this I am new to this dlms. Also it is possible please tell me flow of code. I dont understand how this instructions sent through UART.
Hello
I am working on Atmel code my client initialization is done i got reply from meter but there is problem when com_initializeConnection() is called. When debugged It goes upto cl_snrmRequest() function after it is not working. What shoul I do further.
I have completed communication with meter. I am using SAME54 Xplained board. When I sent clock read frame i got correct response(checked on Gurux translator) but I what to print it on serial how can i do this to print it in "2021-05-12 12:25:29" this format
You don't call AARQ for some reason. Only SNRM is called. You need to check this.
Because the connection is not established the read fails.
HI,
HI,
com_initializeConnection generates AARQ automatically. You need only send generated bytes as you have done with SNRM.
Check that parsing UA is not failed and your buffer is big enough to save generated AARQ message.
Hello
Hello
I want to read all objects from meter using Atmel. Where I can get it
hello
hello
Please update I want code to read all object from meter please help
Hello
Hello
Reading association view will return all the objects that the meter can offer in that association.
Is function returning an error or is returned value zero?
Date-time is coming in octet-string and you need to convert it to gxtime. Then you can use time_toString2 to convert it to the string.
