I am trying to read Secure Meter Indian Standard meter using Gurux GXDlmsDirector.
When I try to read the meter data, GX Dlms Director shows error "Service Error Read exception. Service Unsupported".
Older version of Gurux GX Dlms Director is working fine (which is installed on another PC.)
Removing "Access" from
Removing "Access" from "Supported Service" tab makes it work fine.
Thank you for this info. I created an issue from this.
https://www.gurux.fi/node/18121
This is fixed and the new version is released today.
Thank you. I got the update
Thank you. I got the update when I started the application again and this time everything worked like charm.
